I have heard that if you work near oil rigs it is a requirement to have so they are out there. If I remember it has something to do with a butterfly valve that cuts air to the engine and is placed between the turbo and intake.
Its called the igntion switch![]()
The thing cannot absolutely not inject fuel with the ignition off unless you bypassed the ignition somehow. The PCM, PMD and IP are all elecric and all needed to make the IP actually squirt.
We're talking the AIR being the FUEL...
No switch is going to save your ass with a diesel engine.
Yep, I just wanted to make sure the OP and everyone understood that a mechanical kill switch is completely unnecessary unless youre in that one situation where you are in unbreathable environment, that is filled with gaseous fuel from a burst pipe.
For a DB2, the fuel shutoff also runs off of ignition power. So unless something is messed up it shouldn't be able to run away with no key on either.
