HD OPS is crap. All OPS will fail, everyone with an OBD1 truck should take the LP off of the OPS, with the OPS relay mod. I would go with the ACDelco OPS becuase I would trust its sender capability most, although any OPS will be fine to work with the OPS relay mod. This is one of the MUST DO reliability mods on a non-OBD2 truck. OBD2 trucks solved the failing OPS problem by always sending power through a relay triggered by the PCM. It has the OPS too, but with parallel power sources it takes load off the OPS, or even if OPS fails the relay still provides power. So you see GM fixed their mistake, left it up to us to fix it ourselves on older trucks.
