wow thanks for all the responses i sleep for 5 hours and you guys are typing your hands off, lol.
well first to start for gears i dont know what gears where put in the transmission, all i know is under 45 mph i have to be in drive and over 45 i have to be in overdrive, if i dont my truck starts bucking around 40 to 45 mph. Look in glove box should be some codes in there letter & number those are RPO codes which tell which options came with truck I suspect with it being a 3500 code GT5 or 4:10 rear end gears which is what we were asking about
my buddy is a chevy mechanic and said that when the guy had the transmission rebuilt they put in bigger gears for hauling so my transmission and the transmission doesnt know where to kick in overdrive and when it should kick out.
if im in overdrive driver and it starts bucking i drop it down in to 3rd gear(drive) and it it stops. right now im avg 25 to 28 mpg on the highway. i dont know if it is good i dont know if it is bad but it is better than what my ranger 4.0 4x4 was getting that i traded for this truck.
as for tire size im runing 245/75/r16. how would i go for checking the injectors and timing chain? is it easy for someone to do that knows nothing about diesel engines? Ask guy who installed the replacement engine if new injectors & chain were installed then if not or no idea I'd suspect you are due for a set as 100K on injectors is about normal life for them
what is IP and LP and how do i turn them up? as for a budget doc im a disable vet, right now money is tight but getting better mileage is what im going for. IP=injection pump yours is mechanical vs most here having electronic one, LP=lift pump electric pump mounted on frame rail driver side looks like a GM gassers fuel filter, if weak will starve the IP and impact performance, for budget lets go with stock stuff 1st
my va check should be coming soon so im getting a nicce chunck of money from that im just trying to get a ideal on what i need and what its gonna cost if the price is right, ill buy it, im a craiglist junkie so i always find good deals.
the guy i got the truck from said that he rebuilt the engine him self only has about 30,000 on the engine and tranny. but i cant take his word for it until i see the paperwork that he said he mailed to me, but gut feeling is i wont see it.
what i want to do is get another engine either another 6.5, or 7.3 or 5.9, and rebuild it myself so i know for sure what has been done to the engine. what type of gauges would you recommend? Boost & EGT at minimum, trans temp is handy if towing
i just replaced the antifreeze, and the t stat got the t stat from advance dont know what one it is. Can you post p/n of the Advance stat as they often recommend the wrong type, what antifreeze color came out when drained and what did you put back in
