I would like to check drive pressure also. Someone told be me low compression won't make turbo lag ,but I'm not so sure.
The 6 bolts per cylinder needs only 18 bolts, the 6.2/6.5L has 5 per, with 17 bolts..... the inner two cylinders share bolts.
jim.
That does make more sense, that 6 per cylinder has a much more logical balanced layout than the 5 per cylinder design. Next there should be the 21 bolt 6 per cylinder design with thicker cylinder walls so they can make even more boost.
