RNation
The symptoms are, it loses power going up hill, black smoke, the engine shakes around a bit, when I go to take off from a stand still it bounces around a bit, and when I'm stopped at a light or something it jumps a little like it wants to take off.
I have had a leak in my fuel filter/housing for a couple weeks, but this problem just started last night. Honestly my fuel filter problem started when I switched to an electrical lifter pump (it has 10 - 14 psi). I did put the mechanical one back on to see what would happen. It ran a little bit better but not full force.
I'm curious if the filter/housing isn't made for that psi that it could have messed with it, then down to the IP. I'm sure theres such a thing as to much PSI to the IP, but how much is that? The IP I have isn't that old, I think it's around 8-10 months old.
