Torx tamper proof ??
Nothing is tamper proof,with the right tool any thing can be taken apart.
If that don't work,a BFH or a torch get the job done,maybe not exactly as intended but done anyway :D
Yep - 'Tamper-proof' fasteners have a pin in the middle, so a 'normal' torx bit won't socket into the hole.
Also known as 'Security-Torx'
http://en.wikipedia.org/wiki/Torx
Also known as, Those @#$$% #@%$ %@%$% %$@#$ !!! Now I gotta go buy another set of tools.
They used those on the IAC motor on my Impala. Ya really think that's something that needs security???? Good grief.
I removed all of mine and replaced them with Polished hex-head cap-screws and washers from Fastenal on my Bonne. Looks better, and way easier to use. The bolts are M1x2.5, IIRC.
But yes, security/tamper proof torx have a pin in the middle.
:rof:
Oh wait... Do I have to put it back together? :skep:
I took a cheap torx set to the drill press... now they're hollow :D
Only worked for the bigger ones, though. I lack patience, I fear.
you can buy cheap a cheap set at sears.
Youll need them to get into some p-pumps to "turn then up".
