3500GMC
What T F, over
More specifically, ring gaps, piston to wall clearance, deck height, head gaskets.
Ring gaps:
If one had a choice on ring gap, using an over size ring set, file fitting each cylinder, what would be a good ring end gap to shoot for? (6.2 turbo)
What's the N/A 6.5 ring gap compared to the 6.5 turbo?
Is there a GM spec for a turbo 6.2? (banks)
Piston to wall:
There is a .001" bigger finished bore for 7&8, should the same apply to a 6.2? (I'm thinking yes)
Deck height:
How could one determine if a block has been decked? Looking for a factory spec here to determine this, I think? Measuring what I have to compare it to...
Head gaskets:
As far as aftermarket, what are the differences in 6.2 & 6.5 head gaskets? .010" thicker are available through Fel-pro to help with a decked block.
There seems to be confusion on the BORE SIZE affecting compression. I've read on here of some guys thinking a BIGGER bore LOWERS compression... This can't be, can it? Think swept volume of a cylinder.
I'm needing to get the compression 'right' for a turbo 6.2. I don't want to butt a ring or blow head gaskets down the road.
Thoughts?
			Ring gaps:
Piston to wall:
Deck height:
Head gaskets:
Thoughts?
