Your power piston seal is leaking. There is a drain hole between the hydraulic booster and the master cylinder. If you check where the pedal rod enters the housing the input rod seals are most likely also leaking. MBM makes a repair kit $40 - $65 plus freight. It is worthless if you have a staked pedal rod as you must saw it in half and no one sells the replacement pedal rod, that I could find. See the attached instructions.
Know your vehicle's RPO code before trying to buy a replacement from the parts stores.
JD6 : BRAKE, HYD POWER, DISC/DRUM, 7200 LBS
JD7 : BRAKE, HYD POWER, DISC/DRUM, 8400 LBS
NAPA $163.00, The wrong booster was in the box.
Auto zone $200.00, two days. TOO LONG A WAIT.
O'Rilley $210.00 in stock. I had to go back and get my output rod assembly from the core. We swapped the new part and core and I missed the paper that said to reuse the output rod. Limited Lifetime Warranty. I keep my vehicles a long time and it pays back in parts costs.
If the new part does not have the exact same build as your old unit I would not buy it!
Removal can be frustrating, the retainer clip for the brake switch and pedal rod is a PITA. I finally just pried it off and straightened it back out. This is located directly above the steering shaft.
Repair
1. Discharge the accumulator. Engine off. Depress the brake pedal 5 - 10 times.
2. Unbolt the master cylinder from hydraulic booster and bend lines to locate out of way.
3. Disconnect input rod from brake pedal and remove brake switch from input rod.
4. Disconnect hoses and plug hoses and ports.
5. Remove 4 ea nuts from mounting bolts.
6. Remove unit.
7. Reassemble in reverse order
8. Bleed air from system. Fill reservoir and keep full. Start engine. Rotate steering wheel stop to stop while depressing brake pedal repeatedly.
I thought I could save some money with the seal kit but I should have just bought a reman from the start.
