Didn't give it a chance. I have 235k on this engine and it needs to go at least another 50K before I replace it.
Was running with the cruise on, kicked the brake to slow down and the truck never lost speed. Then I turned the cruise OFF at the switch and never lost speed. I then clutched it and put the trans in N. The truck then started gaining speed.
I then shut it off and pulled off the road. After opening the hood and check all of the connections to the remote PMD and cable (good), I then started it up again. After a few seconds of somewhat rough idle, the engine slowly took off again. I called AAA for a tow.
Living in one state and working in another (on the weekends), I didn't have time for more in depth diagnostics, so I had it dropped at my local mechanic who is 6.5 diesel competent. That was last Saturday. I explained the situation and he said he had a plan for diagnostics, but was going to call me Wednesday with the results.
So he called yesterday and said that he drove the truck for 20 minutes up and down the country roads around his shop, at various speeds and loads, and could not reproduce the problem. He put his scan tool (make unknown) on the ECU and could not find any codes, which is not surprising as there was no MIL during all of this. Everything else checks out: fuel level, fuel pressure, fuel filter, newer injectors (from Tim at Accurate). The best that I am left with is that I have a malfunctioning DTech remote PMD. I intend to replace it soon and need to make a decision about what to put in its place. The one thing that I am SURE of is that I will be using a heat transfer compound this time instead of the heat transfer pad. This was a suggestion from Tim at Accurate as possibly the only "base" I didn't cover when making my remote PMD cooler assembly.
Regards,
