your problem in concise language (ie: Cranks but won’t fire). ____________________________
Demographics: tell us about your truck and your ambient conditions:
- Year: 1994______
- Truck model and class (ie: c2500) _k3500________
- Automatic or Standard __auto________
- Mileage: (indicate miles or km) 171 thou_________
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) _new pmd ,injectors and glowplugs__________
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? F turbo______________
- Ambient outside temp: (indicate *C or *F) __________
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) _#1 diesel________
- What fuel additives are you using? __none_________
- Where are you located? _Georgia____________
General maintenance: inspect and evaluate the condition of each. When were they last changed?
- Air filter __new_______
- Fuel filter _old________
- CDR Valve? __?_______
- Coolant – last flushed/replaced at _07-08-10____________
- Oil – synthetic/regular, changed at _07-01-10__________
- Batteries – state of charge, (matched set) replaced at _06-25-09____________
- Battery cables and grounds (removed, cleaned and tightened): _07-02-10_____________
- Glow Plugs - how many miles on them? _7000________ What type? __?___________
- Injectors - last changed at _7000 miles ago______________
History: (Describe how the problem first appeared.)
- What were you doing when it happened? _towing 27 ft camper_____________
- How was the truck running fine before this problem appeared? _fine____________
- Has this problem ever happened before? __no_____________________
- Describe any related factors that might be part of the problem. _fuel filter leaking_____________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) _Y___ And? 15 18 35 49 78 85 87________
Diagnostics:
1] Starting:
1a] Does the engine start? __Y_______
1b] Does the engine crank over? __Y______
1c] Are your batteries fully charged? _Y________
1d] Have you removed, cleaned, and tightened all battery connections? _Y_______
1e] Does your Wait to Start light come on for a time? How long? _Y 4-5 sec________
1f] Does your glow plug light come on? _Y________ For how long? __4-5 sec_______
1g] Do you see smoke from the exhaust while cranking? What color? N________
1h] Does the Service Engine Light Glow during Start/bulb check? Y________
2] Fuel Issues (if not running):
2a] Can you hear your lift pump working? __Y__________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? __Y_______
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? _Y__________
2d] Loosen an injector line and crank the engine - does fuel come out? __Y_______
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? __Y_________
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) _remote on driver fender__________
3b] Condition of Extension harness (if used) Vendor or Homemade? _new homemade________
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. _good________
3d] PMD Make: _styn__________
3e] PMD Age: _07-11-10____________
4] Stalling Issues
4a] Do you experience stalling only when hot? ____no stalling________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) _no_____
4c] Does pouring cool water over the IP seem to help with restarting? not done_________
4d] Is stalling momentary (engine recovers)? _________
4e] Does SES light come on when engine hiccups? __no _______
4f] Does cruise control quit working when engine hiccups? _doesnt work anytime__________
4g] Does re-starting seem to reset engine, restoring cruise and power? __no_______
4h] Changes to dash lights or instruments during stalling events? ___no________
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? __no_____
5b] Any bubbles or oil film in coolant overflow tank? _no______
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? __no________
5d] Excessive white smoke from exhaust on cold start? no_________
5e] Excessive black smoke from exhaust under hard acceleration? _no_________
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? __no_________
6b] Maximum boost under load? ___?_________
6c] Have you added a performance PCM (reflash) or Chip? _new chip in new PMD_____________
6d] Have you changed exhaust / downpipe / crossover? ____no____________
6e] Wastegate – mechanical or vacuum (OEM)? __vacuum____________
7] Temperature-related Issues:
7a] Single or dual thermostats? __single__________
7b] Have you replaced them lately? Manufacturer of replacements? _Y Advance Auto ?________
7c] Have you pulled and cleaned Radiator and coolers lately? _new radiator on 07-11-10___________
7d] Have you replaced the fan clutch? Manufacturer of replacement? ___no_____
7e] (winter) Have you tested your antifreeze? Good to what temp? 07-11-10 -34 degrees__________
7f] (winter) Are you using a winter grille cover? _no__________
List and describe any other factors which are not addressed in this checklist. We can’t see, hear, smell, or touch your truck, so the more descriptive information you can give, the more likely it is that somebody can assist
