TurboTahoe
Recruit
- Messages
 - 790
- Reaction score
 - 6
Excellent job and photos, Barry. Thanks for taking us on your build journey. It's fun to watch!
-Rob
			-Rob
Any idea where to find a "good " drain plug set-up without spending $300 for a cast aluminum pan? This "help" one was the only thing I could find locally.Hey Barry, Looks like a show truck! One thing I would suggest is not using the drain plug kit in the picture. It is not a tappered pipe plug but a oring seal. It is garrantied to leak.
I know the help section has a few different choices, but none I have seen would seem to work well. Next time I do one I will find a weld on 1/2" bung. Maybe Summit racing?
The other problem with the one like you have now (like the couple I have had) is its not even a 1/8" pipe thread, I thought I would solve the problem and intall a pipe plug. Well its wasint even close to fitting.
Maybe if you have to do some kind of custom thing you could weld in a fitting to allow the Fumoto (sp?) drain like used for engine oil??
Go to any oilfield supply and get a npt coupler and cut it in 1/2 and weld it on the pan.
They weld easy, they're cast steel not cast iron. I weld them all the time. Shouldn't be a problem finding them in Houston. They also make weldable npt fittings, they already have a bevel at the base which isn't needed in this case.
It's got a 5th wheel ball hitch in the box.I have a triple axle flatbed trailerSo far thats all it is!
Looks fantastic Barry! Can't wait to see her all put back together and fired up.
What are the plans for use on this vehicle?
I opened the package. It is a POS.:mad2: The mini o-ring will tear the first time it's tightened.I think 1/2" would be a bit large. 3/8 or 1/4 would be more than big enough. Time to look through the pipe fitting drawers. I have`a spare tranny pan on it for temporary sake to not scratch the painted one up. Looks like i'll be repainting the pan after the welding:ANGRY_~317:
That may be possible.Right now I'm thinking on the lines of drilling and tapping a piece of steel plate and welding that to the pan.A regular pipe coupling would look kinda uglyWithout one in my hand I cant say, but how does it look if you drill and tap for a pipe plug? Is it doable?
