I got the shut off solenoid off by clamping it in a vise and turning the pump,the hex head was rounded off. I also took apart the charge pump,and was debating if it can pump a lot or not,kinda think it can because of the large diameter. All the ports on the pump are charge pressure except the pipe plug,which is not 3/8 or 1/2. Charge pressure comes from the internal pump and into a passage on the ip housing pass front,then goes straight back to a rear bolt hole,which goes directly into the head which has a internal passage that goes the whole way around and has 8 holes that line up withe the 2 holes in the rotor when the plungers are between lobes on the cam, it is then pressurized by the plungers, then enters a hole in the center of the rotor, and can go one of two places,depending on the fuel solenoid,with it closed it will go directly out a hole in the rotor,and to which ever cyl hole it lines up with in the head,when the fuel solenoid is open the high pressure fuel goes into two holes in the head,which are charge pressure,and then goes into a passage in the pump body, and goes straight front to the inlet where the regulator is,and returns towards the lift pump. The charge pressure is sealed from lift pump pressure,by the oring at the bottom of the inlet fitting except what is passed through regulator valve,which is probably open most of the time since it is slotted. Since the high injection pressure is dumped into the charge pressure it looks like it could easily get very high at light loads,and higher rpms.
