My understanding is that Sea Foam and similar solvent-based quick-action cleaners might be dangerous. The concern is that if the engine has heavy varnish and carbon deposits, then the solvent will loosen them up immediately, placing the deposits in suspension in the oil. If the deposits are heavy, then they might stay 'thick and goopy', and clog oil passages, causing engine damage when used in the crankcase. This is also true when using in fuel in high concentrations, except there they would just clog the filter and stop the engine.
I have run hundreds of gallons of biodiesel through both my 6.5s. I did it in stages. Since B100 (100% biodiesel) is easily available to me (and has a very high solvent action), I started with a 20% mix with #2 petrodiesel for a couple of tanks. I then moved to B50, then B75, finally B100. It took me many tanks to get to B100, and I had to change the fuel filters a couple of times as they loaded up. And yes, they were loaded up for sure. Now, they seem to have very little deposits on them, especially when I am running B100 in the summers.
I am therefore pretty sure that my fuel system and intake systems are pretty clear and clean. The rigs certainly run well.
As far as the engine oil sump and internal deposits, I haven't done anything so far. I am considering using a slow-acting solvent that goes under the name of "AutoRX". It is supposed to SLOWLY remove the buildups over thousands of miles. The idea is that by removing them slowly, you can keep everything in suspension, and the oil filter will catch the dissolved crud. It's pretty expensive compared to Sea Foam, however.
I DID use Sea Foam in my wife's mini-van however. My reasoning there was that I've always used synthetic oil in it, and from what I could see, the build-up of deposits was quite minimal. I put Sea Foam in the crankcase and ran the car at high idle for 45 minutes. I can certainly say that the oil seemed darker than normal, so I am pretty sure I flushed some deposits out.
Anyway, I wanted to share the concerns I have with some of the 'quick' engine flush concepts. Putting Sea Foam into the fuel manager seems like a fine idea. Should help clear the injectors.
I'm probably going to pull an injector off the Tahoe and get it tested at some point, or just replace them all. I'm pretty sure they are the originals, with 185K on them. I wonder how much the B100 has cleared them. The truck certainly is running quite well.
-Rob
