Looking out some of those videos you are using all that extra fuel also that's awesome.
You hit nail on head grasshopper. I dislike lots of black smoke, when the engine is running at WOT and the turbo is fully spooled, I'm expecting nothing more than a light haze. Other than that I've got too much fuel for air.
A little at a time does it. Many tracks I've raced at I have had onlookers that have found me at the pits, still having to ask the question "is that a Diesel" ):h
Turn up the fuel, change the injectors, adjust the wastegate on the turbo, watch the EGT gauge.
Turn up the fuel, change the injectors, swap the turbine housing on the turbo, then adjust the wastegate, watch the EGT gauge.
Turn up the fuel on the fuel curve with governor, swap the turbocharger out for something larger.
Tune for smoke (the stack through the hood was key for this, that's in the past now), tune for safe EGT's.
Now I'm at the limit of safe boost, going to have to beef up the valve springs to account for the exhaust back pressure of the turbo and the intake pressure of the charge air. Or, add NOS... Blue bottle sitting in the bed as I write (nice trade).
J
