Pruittx2
Been around a bit
6.5 Diesel owners
List of Things to make it Reliable
1) Relocate PMD Outside of Engine compartment on HeatSink
2) Pull Radiator, to clean in between All coolers, Use Only AC-Delco t-stats
3) New oil cooler lines with real plumbing
4) AC-Delco ONLY OPS W/Relay Mod for OPS reliability (on years needed)
5) Fuel Pressure gauge to keep tabs on Lift pump, fuel filtering issues
6) Battery cable fix, using Bolts&Nuts & Adding #4 wire from Alt to + terminal
7) Pull and clean ALL grounds!!
List of Mod's to get the most out of your rig
1) 4" exhaust with 2.25" or 2.5" crossover
2) Boost and EGT Gauges
3) Manual Wastegate Controller
4) 97+ Air Cleaner Assem or better
5) H/O Water Pump, Duramax Composite Fan with a H/D Fan Clutch or fan clutch Mod
6) Performance chip for more fuel, better idle, More Fun!
7) Feed The Beast Mod
8) Bosch Duraterm or ACDelco 60G Glowplugs with GlowPlug Override Mod
9) Known good injectors, if you don't know Test/Replace them! Bosch or Delphi
10) 1993 Lift Pump or better H/D unit ie Walbro or others
11) Then we can look to add bigger turbo's Att or Holset,
Water/Meth or Propane injection systems,
air to air or water to air InterCoolers, ect.
The explanation, and expansion of info on any or all of these mod's can me found here:
http://www.dieselplace.com/forum/showthread.php?t=53309
I'm sure others can comment on a few other things, that should be on this list.
But for new members thinking of getting all they can out of there rig, This should about do it.
Guys that are pulling 20,000+Lbs here, have these if not more mods.
Now start saving that coin, and get busy!
