Small turbo = quick low end boost. Chokes up high (RPM)
Big turbo = no low end boost. Kicks on with high load but low restriction - will not choke. (Choke here is referring to the exhaust not overspeed.)
It is all a trade off.
Aye, but by changing turbo's BACK to the GM-X Buddy reports he COULD spin the tires, (makes sense, quick low end boost), but 635 stated he only could do that with the ATT.
Rough Statement, alot is in play here..
4 tires vs 2, unsprung weight, 635 could have been visualizing running onver Ian and power braking it to 3k RPM!!!)
I really can't wait for the ATT. I live around some really nasty hills, and my engine is ALWAYS loaded....
After driving around with TM no chip, I don't push over 9 boost up hills. I have to feather the pedal up highway grades for it not easily go over 9 lbs... I just don't want to code (can't stand SES lights
... I know I'll reap every last benefit out of that ATT. Matt wants that 'Feel Good Feeling' Buddy described!
Even heavy as I am, with the 4:10 gears, she' s always super peppy at low speeds anyhow, so If I loose a touch of that (always a tradeoff as you said), Thats quite alright.
