buddy
Active Member
Hey all,
I have a blinking parking brake light, 4 short then 1 long, its constant from moment I turn key to on. Anyone have the definition for this?
I can't find the definition of this in my manuals, but discerned that typically a fluid pressure problem to front or back. Well discs and calipers all looked good and plenty of fluid in the master cylinder reservoir.
I pulled rear wheels off and opened drums and on one side the cylinder has no seal left and is leaking, and other side looks to be leaking a little too. I haven't had to add fluid at all in the last 2.5 years, but imagine this has been this way a while since the cylinder seal is so far gone.
Is swapping the cylinders an easy task? It looks like not a big deal. The drum pads look fine too, probably because they havent had good pressure in a long time.
Also, someone that put my new tires on thought my axle seal was leaking. I dont think it is, because I havent seen a bit of fluid outside of the drum, and the wet brake dust in there could have just been from the brake cylinder leaking. I'm going to fix the brake fluid leak and clean up the area and monitor occasionally. Are the seals easy enough to replace if there is a leak? Get tapered repair bearings, new seals, pop open the differential to pull the axle out?
Thanks for any insight!
