If you saw my thread about no oil pressure on a new build knock off GEP block from Clear water, you know that I was having trouble getting oil to the top end of my motor.Well after hours of troubling shooting ,asking lots of questions, fixing mistakes like missing bypass valves,and oil galley soft plugs I pulled it back out of the truck and tore it back down. What I found was a solid (I mean SOLID) wad of metal shavings
from the milling of the block stuck in the oil passage between the rear main cap and the ops. It was so solid I had to drive it out with a steel rod. No amount of pressure wash or air would have ever removed it. Enough oil along with shavings made it to the rear main bearing and #8 rod bearing to toast them but everything else was fine.Sooo I called Clear water just to talk about the situation. I got John on the line, told him this story and basically he told me tough s--t.No guarantee no nothing. Now I wasn't looking for money, Just wanted to inform him of the problem.What a crappy way to do business:nono:. If you're thinking about Clear Water I wouldn't:nonod:.Look some where else .An apology wouldn't have cost them a dime and I couldn't get one.This has cost me hours of labor and $300 more in parts.
