$199.00 + shipping. This is a brand new ENGINE OIL COOLER and HOSES. Complete kit For 2wd and 4x4 trucks, 1988-2000 Gas or diesel. The cooler is a direct bolt in using the factory oil cooler brackets. Made to replace the stock cooler. The hoses are Stainless Steel braided and teflon lined. Hoses have #8 female swivel flare on each end. The fittings on the block are 90 degree 3/8" pipe to #8 flare/JIC or 1/2" pipe to #8 flare/JIC. Both sizes are included in the kit. The cooler has 1/2" female fittings. The kit will come with all the fittings needed to hook the hoses to the cooler and engine block.
BONUS:!! You also get a free plastic spiral wrap/covering for the hoses. They will help guard against the hoses rubbing on other parts.
Kit is for 2wheel drive and 4x4 trucks. Will work on gas and diesel powered trucks.
Why buy this kit?
This kit is made in North America.
The original cooler lines are very prone to leak at the crimped connections.
The original aluminium lines are known to crack or the retaining clip can rub a hole in them.
The original replacement lines and cooler are expensive and you get the leak prone hoses/lines again.
The original lines use an "Oring" seal and it is easy to over tighten and damage the oring.
Why buy this kit?
