Gulfsurfer
Member
- Messages
- 42
- Reaction score
- 3
Well, after replacing the stock system with a Diamondeye 4" system over the holidays (http://www.thetruckstop.us/forum/showthread.php?t=19218), I found the sound too loud for my liking. The exhaust tone sounded good when the engine was unloaded, but under load it was really loud. This vehicle is my tow vehicle, usually hooked up 95% of the time to any one of the 4 trailers I regulary tow, ranging in weight from 2,000 to 10,000.
So I searched for a quieter muffler than the Diamondeye straight thru glass pack:
The first alternative muffler I tried was the Wagner "Big Truck Muffler", shown in the pic above-left, it's the longer muffler next to the shorter stainless steel Diamondeye muffler that came with the exhaust kit. The middle pic shows the Diamondeye muffler's straight thru design, as is the BTM shown at right. The BTM is longer than the Diamondeye but it is not glass packed. I didn't know that when I ordered the BTM. I thought the longer length would quiet the exhaust, it didn't though. No glass packing gave it a raspy "industrial" sound (that's the only way I can descirbe it). What it did do though, was make the turbo sing like you wouldn't believe :smile5: However, what I wanted was quiet. The search continued:
I then ordered a "wife pleaser" muffler from SSDiesel (I know, what a wuss-sounding name!). See pic above left, it's the muffler to the right. It turns out it's actually manufactured by Heartthrob. They have a great website, but you can only purchase their products thru a dealer. It's cheap anyway thru SSD ($89).
It's a longer muffler than the Diamondeye muffler, not as long as the BTM though. It's not glass packed either but it is chambered and it is fatter (8" vs 7"). The middle pic above shows how they chamber it, it's actually just an eccentric divider plate halfway thru. That divider plate and the larger diameter appears to do the trick with regard to reducing noise levels.
The pic above right shows that it does have a preferred installation orientation, the open end of the louvers inside the muffler's flowpath will point "upstream". I followed that orientaion. I know that some guys reverse their mufflers to point the louvers' opeings downstream, but I figured Heartthrob knows more than I do about mufflers and noise levels.
It's tone is much nicer than stock ("rumbly") but much quieter than either the Diamondeye muffler or the BTM under load. Turbo whine is still apparent (less than the BTM though) and performance hasn't degraded appreciably from the Diamondeye straight thru muffler. It's a keeper!!!
BTW, if I hadn't used the band type exhaust clamps, I wouldn't have been able to swap these mufflers out very easily. I did each muffler swap in about an hour, counting having to cut fill-in pipes to account for differing muffler lengths.
I'll be posting the Diamondeye and BTM mufflers in the classified section, in case anyone wants to buy them for pretty cheap. They have prolly less than 5 hrs run time each.
