Throwing codes again!!!
Its not whether the LP itself works, it all about if its gettting proper power when its supposed to. Thats why you need to check pressure at idle and while driving.
disconnect the gauges fuse and check the resistance between the fuse contact and chassis ground. If If there is no continuity with ignition off then it must be shorted from something switched. Its possible that SES or STS light shorted out, but those are grounded by the PCM when switched on.
Got the Alternator tested, it's good. Ohm'd the A port it comes out 0. Tried unplugging things 1 at a time and turning the ignition on. Unplugged the OPS, glow plug controller, both temp sensors, LP, and no change. The truck still won't start. Turns over and blows whitish smoke out the exhaust. Still blows the gauge fuse as soon as the ignition is turned on.
Got some help with the truck yesterday evening. My cousin came over and helped me chase the short. Looks like its in the fuel heater on the bottom of the fuel filter housing. Is the fuel heater necessary for the truck to run?
I finally found the schematic showing that it goes to the fuel heater. It was on the Glow Plug schematic, go figure. everyone should use All Data, its very useful. The Gauges fuse seems to go to just about everything.
