twisted off glow plug
chevyCowboy
I might be crazy but i ain't dumb
Springfield Nebraska
i was getting on of my 3 sets of heads ready to take to the machinest and i twisted off one of the glow plugs:mad2::mad2::mad2: any one got any ideas how to get the darn thing out of there. its flush with the head
Easy as pie, have the machinist do it:D
Try an easy out or weld a nut over it and turn it out
I would heat it and put Sea Foam on it, then try an easy-out. maybe reheat and retry once, then off to the machinist.
And use neverseez at least every 2 years
i really dont think an easy out is ganna do it but maybe with heat i had about 20in of leverage on it befor it twisted off. im pretty sure it turnd alittle and then quit and i tried harder and then it twisted
I'd heat the cast around it, then lay either a nut or washer of appropriate size over it & weld together.
The heat's the key to breaking the corrosion bond & expanding the cast iron around it so there's less friction or interference/tension fit. If it starts to turn with the surrounding cast hot, but then tightens up - just stop, reheat, & go again, 'til it's out.
I sometimes find a washer a more comparable thickness, so easier to weld to something thin walled like this.
The problem w/ EZ outs is usually that when they break, they're a much harder material so that much harder to drill out.
You could also try tapping/spinning it out with a chisel after heating the surrounding cast iron.
Been there, tried all the above, didn't work. BUT, I ultimately conquered. I'm sure every little bit helped, tried all the penetrating oils, heat/cool, easy out-broke that. Couldn't get a welded nut to hold either. (Did get the easy-out out by welding a nut to that) I would suggest melting parrafin wax into the threads with light heat (not cherry)
My little used set of left handed drill bits were what completed the task. Drill in about 3/8" IIRC, not into the seat, first with 1/4, then 5/16, then 3/8. The 3/8th bit is barely smaller than the threaded diameter of the glowplug, it caught and spun the rest of the glowplug out cleanly. I was able to thread the new one by hand to finger tight.
Good luck.
