Doing It Again!
MAGNUM SERVICES
Intelligence Guided By Experience
Covington,Kentucky
6.5 Engine Diagnostic Troubleshooting Checklist
Copy and paste this checklist into a new post, then answer all the questions by typing in your data into the (red) blanks as indicated - click in the middle of the blank, start typing.
Problem: Explain your problem in concise language (ie: Cranks but won’t fire). Quits whenever it wants to_________________________
Demographics: tell us about your truck and your ambient conditions:
- Year: _1996_Sierra SLT Ex. cab long bed 4X4____
- Truck model and class (ie: c2500) _2500 8600 gvw________
- Automatic or Standard _auto- 4l80e_________
- Mileage: (indicate miles or km) _145,000________
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) _IP 3 years ago, injectors 3 yrs ago, LP-PMD- fuel tank and lines May 09' __________
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? _"F" Turbo non egr_____________
- Ambient outside temp: (indicate *C or *F) _80f or 0f, does not matter_________
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) _# 2 Diesel________
- What fuel additives are you using? Power Service Cetane Boost year round___________
- Where are you located? _Covington, Ky. just south of Cincinnati, Oh.____________
General maintenance: inspect and evaluate the condition of each. When were they last changed?
- Air filter May 09_________
- Fuel filter _May 09________
- CDR Valve? _3 yrs ago________
- Coolant – last flushed/replaced at Replaced dexcool with regular green 3 yrs ago____________
- Oil – synthetic/regular, changed at _Rotella 15w40 May 09__________
- Batteries – state of charge, (matched set) replaced at _Feb 09, matched set, fully charged____________
- Battery cables and grounds (removed, cleaned and tightened): __Original cables, cleaned yearly____________
- Glow Plugs - how many miles on them? _SS Diesel with new controller, 10,09________ What type? __quick heat___________
- Injectors - last changed at __Rebuilt GM replaced 3 yrs ago_____________
History: (Describe how the problem first appeared.)
- What were you doing when it happened? _Driving_____________
- How was the truck running fine before this problem appeared? _Good____________
- Has this problem ever happened before? _Yes ______________________
- Describe any related factors that might be part of the problem. __none____________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) no codes____ And? ________
Diagnostics:
1] Starting:
1a] Does the engine start? _Yes, every morning________
1b] Does the engine crank over? __Yes______
1c] Are your batteries fully charged? _Yes________
1d] Have you removed, cleaned, and tightened all battery connections? _Yes_______
1e] Does your Wait to Start light come on for a time? How long? _yes, normal time________
1f] Does your glow plug light come on? _have not noticed________ For how long? ___N/A______
1g] Do you see smoke from the exhaust while cranking? What color? _have not noticed_______
1h] Does the Service Engine Light Glow during Start/bulb check? _have not noticed_______
2] Fuel Issues (if not running):
2a] Can you hear your lift pump working? __Yes__________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? __Yes_______
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? __Yes, gauge before IP, 8 psi with key on_________
2d] Loosen an injector line and crank the engine - does fuel come out? _Yes________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? __Yes, new locking cap replaced 2, 09_________
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) remote mounted on SS Diesel heatsink, New Stanadyne "Grey" updated model___________
3b] Condition of Extension harness (if used) Vendor or Homemade? _Yes from PMD Cable with Gold ends________
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. _all clean and tight________
3d] PMD Make: _Stanadyne upgraded "Grey" model_________
3e] PMD Age: _New, 5 09____________
4] Stalling Issues
4a] Do you experience stalling only when hot? no, after truck is running five minutes or five hours___________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) _under acceleration, idling, hot or cold outside_____
4c] Does pouring cool water over the IP seem to help with restarting? __have not done this_______
4d] Is stalling momentary (engine recovers)? _sometimes it will start right up and other times after sitting for two to three minutes________
4e] Does SES light come on when engine hiccups? __no_______
4f] Does cruise control quit working when engine hiccups? _never use cruise control__________
4g] Does re-starting seem to reset engine, restoring cruise and power? yes_______
4h] Changes to dash lights or instruments during stalling events? __no_________
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? _have not noticed______
5b] Any bubbles or oil film in coolant overflow tank? _no______
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? _no_________
5d] Excessive white smoke from exhaust on cold start? _no________
5e] Excessive black smoke from exhaust under hard acceleration? _no_________
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? yes, fuel pressure under hood before IP, 8 psi with key on__________
6b] Maximum boost under load? ___unknown_________
6c] Have you added a performance PCM (reflash) or Chip? _no_____________
6d] Have you changed exhaust / downpipe / crossover? _crossover with Dealer installed pipe in 05_______________
6e] Wastegate – mechanical or vacuum (OEM)? _vacuum, original wastegate, new vacuum pump 3 yrs ago____________
7] Temperature-related Issues:
7a] Single or dual thermostats? _single 180 f_________
7b] Have you replaced them lately? Manufacturer of replacements? _yes, Delco,replaced 09________
7c] Have you pulled and cleaned Radiator and coolers lately? _no___________
7d] Have you replaced the fan clutch? Manufacturer of replacement? _no_______
7e] (winter) Have you tested your antifreeze? Good to what temp? _yes, - 40_________
7f] (winter) Are you using a winter grille cover? _no __________
List and describe any other factors which are not addressed in this checklist. We can’t see, hear, smell, or touch your truck, so the more descriptive information you can give, the more likely it is that somebody can assist you.
I purchased this truck in 2000 with 59,000 miles on it. I have replaced the IP twice, the last one three yrs. ago when the "service throttle soon" light came on. I tow a 16 ft. trailer all summer long and plow snow in the winter. In may 09 I replace the fuel tank, sending unit, lines and LP and filter. The quitting problem went away but resurfaced in Oct. 09 and then ran fine until Jan. 8th while plowing snow._________________________________
__________________
Please include your vehicle details in your signature. Click here to fill out yours.
If you need assistance with your 6.5TD, please copy our Diagnostic Checklist and start a new thread by pasting it and filling it out in detail.
Looking for a 'How-to' thread? Check out the
6.5 Technical Reference Library
=================ΜΟΛΩΝ ΛΑΒΕ==================
you need to extend that pressure guage so it can be read from in the truck while driving. Sure sounds like a fuel issue
Are you sure your locking fuel cap is for a 6.5 diesel???? IIRC there was someone else on here who had an issue with one that would not hold the tank psi or vac the right way. I dont remember which we are supposed to have.
My bet is on the intake mounted fsd.
I just reread the checklist, it doesn't sound like the fsd is on the intake. I just assumed it was because it is ssd. I would also check the ext. harness connections.
NVW, it is on the intake! 625 Fireman, yes it is a locking cap for the diesel fuel fill neck!
Whats going on stranger, aside from the truck issues?
Shoot me a PM and maybe we can try to figure out both of our truck issues. I may still have your number in my PM's but not sure, been busy here and Kim wrecked her van, not her fault but still a hindrence.
Let me know and hope you get it figured out soon.:thumbsup:
You DO realize that mounting an FSD on the intake is not a good thing, right?
See if somebody near you has one you can try - it's hard to diagnose when it starts back up after stalling, but that would be my guess... leave the fuel cap loose so the tank has lots of vent, just to rule that out.
JiFaire, no I did not know mounting a pmd on the intakes was bad and I'll put the old fuel cap back on! Agent Skeeter, I think I still have your number somewhere around here!
Keith, some people mount their FSD on the intake and have no problems, but overall, I've not been impressed with that location. Some fail in as little as 2 months, few make it past 2 yrs.
It's HOT there, and getting rid of heat from the PMD is a matter of having some kind of temperature differential between the heatsink and the surrounding air; the greater the differential, the faster it can shed heat. If the air is hot enough, it won't shed heat.
Mounting them outside the engine compartment, they never get too hot to handle. I'm surprised Leroy didn't tell you that... did you buy the PMD from him, or just a cable?
I tell everyone that informs me they are running a PMD inside the engine bay.
How the heck did you know if he has one of mine? I can't even be sure without looking it up.
Leroy
Leroy, I did buy one from you May 09 BUT have not installed it yet! I know, I'm a procrastinator! JiFaire, I can't believe a pmd, especially a new "upgraded" Grey pmd form Stanadyne would go bad in a few months, BUT anything is possible!
Leroy
LOL... The Bear knows, Leroy ...
Actually - look at his answer to 3b] in the checklist in post #1... I knew he had a newer PMD from somebody, and I knew he bought a cable from you.
Great, thanks again. I/we can not stress enough to get the PMD outside engine compartment. If you have not allready done it, you need to check the grounds at pass side rear of intake. On my truck I tried to start it with the intake off after an IP R&R before buttoning everything up. It would not even start until I grounded those wires, so if they are loose/bad I can see them giving an intermentant stalling problems.
Oh man, I read that like 3 times to and did not see it. (It was late, my eyes were tired :ohmy1:)
I need to come up with a "sexy" name so pepole are more inclined to add my products to there signature??
I have a DBA on file for another business called "Magnum Pools Inc" that I never used. Change it up alittle to "Magnum Products Inc". I have been thinking for the past couple of years to attach Magnum to my products names, so customers can identify them better and say
"I have a Magnum P.I. cable on my truck" :D
Remember the show back in the 80's with Tom Cellic?
