There were no instructions on how to bleed the master. I simply mounted it and filled it and fluid poured out the bottom, then I installed the factory line.
This is really frusterating. I tried to drive it today and had to start in gear all the time. It's not getting better on it's own, that's for sure. LOL I pulled the allen plug out of the slave today and let fluid pour out for a while thinking this would purge some of the air out, but no dice.
I'm thinking of buying the line that connects the master to the slave just to make it a clean sweep on the parts.
That way I can't blame this on anything other than my failure to bleed a simple hydraulic system.
I'm almost to the point of bringing it to a shop to do it!
Thanks everyone...
Reply
I have a manual trans and went through he same thing, I had to bench bleed my slave cylinder, and clutch master cylinder and still had air problems.
Have you tried leaving the cap off of the clutch master cylinder and letting the slave cylinder bleed out by gravity. Are you sure the throw out fork pivot ball is intact? A worn out throw out arm pivot will cause the same problem. There is a grease fitting directly under the case in the webbing. close to the throw out opening,
