Problem: Explain your problem in concise language (ie: Cranks but won’t fire).
Stalling. But not like when my PMD went, doesn't really stumble either, just gradually dies down till its idling and then eventually dies completely. And had only driven the truck half a km when it happened, hadn't even warmed up yet. After a few minutes will start back up and idle till it dies again.
Demographics: tell us about your truck and your ambient conditions:
- Year: 1998
- Truck model and class: c2500
- Automatic
- Mileage: 530,000km
- Replaced parts and mods: None
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? Turbo, non-egr
- Ambient outside temp: 5 deg C
- What fuel are you using? Couldn't tell ya
- What fuel additives are you using? Diesel fuel conditioner
- Where are you located? Ontario, Canada
General maintenance: inspect and evaluate the condition of each. When were they last changed?
- Air filter 6 mos. but no kms since
- Fuel filter Same as above
- CDR Valve? Whats that? LOL
- Coolant – Flushed las fall
- Oil – regular changed 6 mos ago, but no kms since
- Batteries – replaced 6 mos ago
- Battery cables and grounds - 6 mos ago
- Glow Plugs - Not in the last 200,000kms for sure, don't know if they ever have been changed and same with the injectors.
- Injectors ^^
History: (Describe how the problem first appeared.)
- What were you doing when it happened? Driving
- How was the truck running fine before this problem appeared? Fine, but it had sat for 6 months after that
- Has this problem ever happened before? No.
- Describe any related factors that might be part of the problem. ______________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) No
Diagnostics:
1] Starting:
1a] Does the engine start? Yes
1b] Does the engine crank over? Yes
1c] Are your batteries fully charged? Yes
1d] Have you removed, cleaned, and tightened all battery connections? Yes
1e] Does your Wait to Start light come on for a time? How long? Yes, about 5 seconds
1f] Does your glow plug light come on? Isn't that the same as above?
1g] Do you see smoke from the exhaust while cranking? What color? No
1h] Does the Service Engine Light Glow during Start/bulb check? No
2] Fuel Issues (if not running):
2a] Can you hear your lift pump working? Yes
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? NA _________
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? NA ___________
2d] Loosen an injector line and crank the engine - does fuel come out? NA _________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? NA ___________
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) Remote
3b] Condition of Extension harness (if used) Vendor or Homemade? New
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. _________
3d] PMD Make: Dunno
3e] PMD Age: 1 day
4] Stalling Issues
4a] Do you experience stalling only when hot? No.
4b] Does it stall under particular circumstances? No.
4c] Does pouring cool water over the IP seem to help with restarting? No
4d] Is stalling momentary (engine recovers)? No
4e] Does SES light come on when engine hiccups? No
4f] Does cruise control quit working when engine hiccups? No cruise
4g] Does re-starting seem to reset engine, restoring cruise and power? No
4h] Changes to dash lights or instruments during stalling events? No
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? NA
5b] Any bubbles or oil film in coolant overflow tank? No
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? No
5d] Excessive white smoke from exhaust on cold start? Not excessive
5e] Excessive black smoke from exhaust under hard acceleration? All the time
Hope that helps.
