Matt Bachand
Depends on the 6.5
Oh yeah, well would you look at that.......she's hold'n a pistol. Don't suspect I ever would have noticed the gun 'til 'ya mentioned it![]()
First thing I noticed was the guns... oh, the pistol. Oh yeah, i see it too!
No but she saw it so I'll probably be changin it. She was from Guns n Babes magazine.
There's a Gun in that pic?
haha - I didn't see the gun either. I actually scroll thru these threads rather quickly - especially with the women pictures because of the place that I work.
Anyhow - getting back on topic, HAHA, I'm not going to worry about the 1/8" of play on the wheels - I'm kind of thinking it might be ball joints anyways. I pulled my skid plate off for the first time - and it appeared that all the greasable fittings were shot/empty. I filled what I could but the tierod ball joints leaked out onto the inside of the wheel, and the lower ball joint, driver's side was split open and appeared to be completely empty. So, I'm thinking that I if I replace the tie-rods, upper & lower ball joints, that would be a good start - but since i'll need a realignment anyways, I'm thinking I should go ahead and get new pitman arms (since someone had mentioned they are known to get slop) and just replace everything but the wheel bearings. I'm running 265-75's so I shouldn't be putting too much wear in that form on them.
I assume that if I get a ball joint tool from harbor freight, and freeze my new ball joints and have a big hammer to remove the old ones, that it shouldn't be too difficult...right? (at least compared to a dodge solid axle)...or is IFS more difficult?
when i replaced the tierods on the dodge i just measured the front side and rear side of the wheel. (or you know - as close as I could get). I noticed what appeared to be a "helper pitman arm" - I really need to find my chilton's manual - but I thought that was pretty convenient- extra support I suppose? Neither pitman arms had a grease nipple.
Thats the idler arm. Attaches to the frame and to the tierods.
I have to wait till Saturday to get to a NAPA parts store due to the hours I work and the drive that I have - does anyone have a Bumper to Bumper store and are those parts alright? Are their any other suggestions? Is Carquest comparable to NAPA premium? Or just order online somewheres?
So...i've decided i'm going with napa premium parts - $49/each for upper ball joints, $55/each for Lower ball joints, and inner tie rods are $24/each and outer are $58/each.
They did ask me if I had welded or forged arms??? as far as the lower ball joints go. How do I find this out?
Also, the chiltons repair manual keeps referring to a tool "J-36202" to increase tension on the adjusting arm when replacing the ball joints. What does this tool look like and what do I need to do instead of going out and buying a fancy/expensive tool?
(Just thought of something - since i'm replacing the tierods anyways - i could just remove those, replace the ball joints, and then reinstall the tierods...right? then i wouldn't have to worry about this fancy, smancy tool))
I bought the tie-rod sleeves when I did mine, just makes life easier for a few bux to not have to undo that crap, plus you have the exact setup so you can count threads and measure side by side for almost perfect line up. Cheap.
I think they made the cast / stamped A-Arm change 96-97 I see it alot on my truck options too.
BTW, before the rockauto 5% discount, you could get AC_Delco balljoints for alot cheaper than napa. Wont have them for this weekend, but they ship lightning fast, usually 2-3 days to me.
Check out the link for balljoints.
http://www.rockauto.com/catalog/x,carcode,1053425,parttype,10070
As for the Tie-rod's you could get Delco Tie-rods, for 20 dollars LESS than napa premium, or moog for even cheaper. Don't forget the 5% code too. Super cheap. Big savings. Tell napa to nevermind.
http://www.rockauto.com/catalog/x,carcode,1053425,parttype,7428
Be careful counting threads on tierods. The replacements may not be the same overall length as the old ones. I don't recall which direction but my new ones were either 1/4" longer or 1/4" shorter than the old tie rod ends. If I had relied strictly on thread count I would have been way off on the toe in.
