Hi, Im new here! I have a 1997 GMC suburban with a 6.5 Diesel that I tow my dirt race car around with. I bought the thing about 8 months ago and have had nothing but problems with it and hopfully I can get some help here. I went out 2 days ago in the morning to start my truck and the lights all came on as always but motor just cranked over...I ended up killing the batt. so I tryed jumping it and still would not start..pulled out the fuel fiter and noticed it was dirty..went to work and on my way home i stoped and got a fuel fiter put it in and i fired right up after bleeding the system, drive it about 10 miles and parked it for the night thinking it is fixed. Went back out the next morning and same thing...no start... got home from work and after habving the batt. charger on all day the truck fired up ran for a few mins and shut off, started it right back up and it ran and shut off again. Got it started again after taking the fuel pump apart and cleaning it. Fired right up, 15 mins later it would not fire so I bleed the system again and all kinds of air came out. 3 weeks ago I put in a new fuel tank so I dropped the tank to check the lines and noticed that the fuel line was bad so I cut the bad spot out and replaced with rubber hose, put the tank back in and still nothing. crank crank crank thats it..I bleed the fuel filter and fuel comes out so I know the pump is working. I have a big race coming up this sat. and need to do somthing fast..lol..im dieing here! HELP I will even except a phone call to resolve this problem, im not much of a typer at 330-383-5035 Thanks
First welcome to DTR this is the place to get expert help, I mean expert not amateur guesses. OK there is a form to fill out in the sticky section (top of the page). This diagnostic form will help us determine what you have and what is normal and not normal.
I would check the Oil Pressure Switch, OPS sounds like it may be intermittent. This is a big problem on the trucks along with the PMD, This is speculation though at this point.
Here is a copy that you can fill out
Demographics: tell us about your truck and your ambient conditions:
- Year: _____
- Truck model and class (ie: c2500) _________
- Automatic or Standard auto__________
- Mileage: (indicate miles or km) _________
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) _
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? ______________
- Ambient outside temp: (indicate *C or *F) __________
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) __1 or 2_______
- What fuel additives are you using? ___________
- Where are you located? _____________
General maintenance: inspect and evaluate the condition of each. When were they last changed?
- Air filter _________
- Fuel filter _________
- CDR Valve? _________
- Coolant – last flushed/replaced at _____________
- Oil – synthetic/regular, changed at _regular __________
- Batteries – state of charge, (matched set) replaced at _____________
- Battery cables and grounds (removed, cleaned and tightened): ______________
- Glow Plugs - how many miles on them? _________ What type? _____________
- Injectors - last changed at _______________
History: (Describe how the problem first appeared.)
- What were you doing when it happened? ______________
- How was the truck running fine before this problem appeared? _____________
- Has this problem ever happened before? ______________________
- Describe any related factors that might be part of the problem. ______________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) ____ And? ________
Diagnostics:
1] Starting:
1a] Does the engine start? _________
1b] Does the engine crank over? _______
1c] Are your batteries fully charged? _________
1d] Have you removed, cleaned, and tightened all battery connections? ________
1e] Does your Wait to Start light come on for a time? How long? _________
1f] Does your glow plug light come on? _________ For how long? __ seconds_______
1g] Do you see smoke from the exhaust while cranking? What color? _______
2] Fuel Issues (if not running):
2a] Can you hear your lift pump working? ____________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? _________
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ___________
2d] Loosen an injector line and crank the engine - does fuel come out? _________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ____yes_______
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) ___________
3b] Condition of Extension harness (if used) Vendor or Homemade? _________
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. _________
3d] PMD Make: __________
3e] PMD Age: _____________
4] Stalling Issues
4a] Do you experience stalling only when hot? ____________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) ______
4c] Does pouring cool water over the IP seem to help with restarting? _________
4d] Is stalling momentary (engine recovers)? _________
4e] Does SES light come on when engine hiccups? _________
4f] Does cruise control quit working when engine hiccups? ___________
4g] Does re-starting seem to reset engine, restoring cruise and power? _________
4h] Changes to dash lights or instruments during stalling events? ___________
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? _______
5b] Any bubbles or oil film in coolant overflow tank? ______
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? __________
5d] Excessive white smoke from exhaust on cold start? _________
5e] Excessive black smoke from exhaust under hard acceleration? __________
6] Performance Issues
6a] Do you have gauges? ___________
6b] Maximum boost under load? ____________
6c] Have you added a performance PCM (reflash) or Chip? ______________
6d] Have you changed exhaust / downpipe / crossover? _
6e] Wastegate – mechanical or vacuum? ______________
7] Temperature-related Issues:
7a] Single or dual thermostats? ____________
7b] Have you replaced them lately? Manufacturer of replacements? _________
7c] Have you pulled and cleaned Radiator and coolers lately? ____________
7d] Have you replaced the fan clutch? Manufacturer of replacement? ________
7e] (winter) Have you tested your antifreeze? Good to what temp? __________
7f] (winter) Are you using a winter grille cover? ___________
List and describe any other factors which are not addressed in this checklist. We can’t see, hear, smell, or touch your truck, so the more descriptive information you can give, the more likely it is that somebody can assist you.
