The question is legitimate, I set out to put together a kit that would allow us as 6.5 people to go backwards, replace the factory equipment if the modification (new turbo) was not to spec. Turbine Doc was the second person besides myself to run one. He was the test bed and was truly critiquing how the kit was made, durability, ease of installation and if the kit could go backwards to the factory gm turbo without having to buy parts to do so. So he is not an easy person to please when it comes to his truck, trust me. I also do not expect the turbo to fail from anything other than lack of oil or forgein objects in the openinng. These are built tough , I have had one apart to see the pieces and have also shown Turbine Doc the pieces and how robust they are made. OIL or LACK of will kill them, that is why everything is supplied, including installation instructions with pictures.
The turbo was designed from the start to be a replacement and not compromise the trucks use of factory parts. Nothing worse than making your truck a one of a kind and needing a part somewhere on a Sunday night after hours. :mad2: Then you beat yourself to death for buying that part, well you know the rest.
The turbo was designed by myself and Hank1948, tested, then street tested outside the company by Turbine Doc, (talk about a critique) sheez. Matuva was the very first customer and he has since continued to be a strong advocate for the turbo, and a good friend who's comments and suggestions I value. THIS IS NOT a one man project this is a DTR project, without the generosity and support of Nick, Unit453 A-Team Turbo would not have a home. So lots of people made this work, a true group project, Sorry for the rant,
