chrisk1500
- Messages
- 875
- Reaction score
- 1
There was another thing that I always thought was bogus - can the diesel engine be run in reverse rotation? Damn straight it can!
I was loading bales a couple of miles away from home with a late 60's Case 930 tractor. The batteries are no good on it so if you stall, you have a long walk home.
Needless to say, I stalled the tractor while hauling a bale up an incline. I put in the clutch and started rolling slowly back down the hill. The tractor was still in a forward gear. I let the clutch back out to push start the machine and lo and behold - a huge puff of black came out of the intake! The tractor continued to run quite well with the exhaust pouring out of the intake bowl and all of my forward gears were actually reverse gears and my reverse gear made the tractor go forward.
I shut the tractor off so that I would not overheat it being that the water pump would run in reverse as well.
I always thought that a diesel would not work backwards and that it would behave like a gasser with a distributor out 180*. Not the case on that old Case....
