jcool
#78 A(ACLU) FNG
What are the differences in EGT's, and power between the exhausts.
Cooling wise, the 5" will keep your EGT's down lower than the 4" but once again you get back to the 500hp thing....
You don't lose bottom end, that is a myth. I like my 5" but there is no real advantage. I don't want to hear the 'backpressure' argument to the 5". The turbo itself is plenty of backpressure.
X2. You could run an open turbo and you wouldn't lose low end power.
I can see a slight loss in low end power due to the fact that the turbo uses the exhaust flow to spool, so with less backpressure in theory it would take longer to spool and hold it for a shorter time between shifts and let offs. Then again, I am a seat of the pants guy, and there is always a "sweet spot" for everything which may very well be a 5" exhaust being used....
Exactly, so the air velocity at the turbo should in no way be affected by the 5" system behind it.True, but the turbo outlet is way smaller than any pipe you'll put up next to it, especially front pipe back.
I have a 4 inch stright pipe on my truck now, I think it sounds great, but I stumbled across a deal that I couldn't pass up and traded someone elses factory exuast for a 5 inch for myself. It is sitting on the side of my house, not sure if I should put it on or not.
