Also I agree that a fuel pressure guage (which can be had from Harbor friegt or other places for around 10 bux) is a must have for any 6.5'er.
In fact, I believe all 6.5'ers should have an in cab gauge for fuel pressure.
When my truck dies first thing I do is crack that fuel bleeder to see if it sucks in. Usualy when IP is starving for fuel it creates a vacuum, and opening the bleeder lets air go IN to fill the vacuum.
Upon next re-start, I would crack the bleeder again and make sure fuel comes out, and the truck doesn't stall.
If it stalls when bleeder is opened, there is inadequate fuel pressure, weather it be due to a clogged fuel sock, bad lift pump, or any other issue.
Thats the easy test without a gauge. Sometimes it will pass this test, but still not enough adequate fuel pressure for proper operation, thats where a gauge becomes necessary.
At least the easy test gets you in the right direction, and all it requiress is popping your hood and turning the bleeder. Can be done at anytime, even broken down in middle of traffic.
