Man, you guys sure got a different idea of fun than I do!
If you go on vacation, and need to find something entertaining to do,
come on down to my place and pull my water pump off and
fix my oil leak
It's only fun on your own truck!
I thinik Gm's main mistake is that they didn't realize 210 was max safe operating temp. Just because things don't go boom instantly doesn't mean damage isn't done. Guage reads red at 260! my stock worn out fan didn't kick on till 230's... My brand new oem replacement comes on at 210, but I have to slow down, and get out of the pedal for it to kick on. I have seen 220 again with my replacement oem fan.
I'm going super duy clutch from Kennedy or Heath before next winter, If i have to drop to 180t-states from 195's just so the clutch DIS-Engages I will. I'd rather have it stay on then not come one. i don't mind having a summer clutch, and a winter clutch (severe duty being winter) as its easy to swap.
My plow is my problem, its huge, and heavy, and blocks radiator front.
I don't want hassles of electric fans for the little time I have the plow on.
Now considereing some doubt the 97 block, When I bought the truck itw as someone's fleet truck. the Temp guage sensor DIDN"T WORK!!! People plowed with it and on highway with my plow she'll get HOT HOT fast...
Now, since I've had it (3-4yrs) the first year before forums, I didn't think 230 was bad either. Thats when the fan kicked in...
Since then I am comfortable with 210, but still worry any hotter.
No signs of cracked block, ZERO blowby, 124k miles.
When I rebuilt a head last winter due to valve malfunction, my cylinder walls looked so perfect they had some sort of spherical mesmerizing effect because your eyes couldn't focus on the walls, as they were so flawlessly mirror perfect.
On a side not here, my truck started UNPLUGGED at 8df ambiets after sitting over night on 7 cylinders (do to valve trouble on 8th). Not much tougher than usual.
Smoked like a champ, but fired right up.
I think most of these blocks cracked from overheat.
