I copied the following from my supplier. I will have to get a price tomorrow as they are closed. Should be around $60-75
.Automatically regulates oil temperature
.Provides quicker warm-ups to operating temperatures
.Prevents over-cooling in cold climates
.For use with transmission coolers and engine coolers
Maintaining proper oil temperature is critical in today's sophisticated engines and automatic transmissions. Installation of an auxillary oil cooler helps keep the oil below the 200°F maximum temperature. However, installation of a remote oil thermostat, in addition to an oil cooler, will help warm the oil up to operating temperatures faster. That is a plus at start-up or on cold days when the oil is thick and takes longer to get into the oil galleys.
When oil temperature exceeds 180°F the thermostatic valve closes, allowing 95% flow through the oil cooler. At temperatures below 180°F the valve is open, with 90% of the oil bypassing the cooler. The remaining 10% of the oil flows through the cooler, maintaining constant system pressure, preventing air pockets and eliminating cold oil shock. Flows up to 20 gallons per minute (GPM). Rated to 200 p.s.i.
