4wdaaron
Hard Worker
I'm having a hard time deciding between cutting off the muffler versus buying a 4in turboback silverline stainless steel from a friend for dad's '02 lb7. Anybody want to steer me one way or the other?
One way is pretty much Free, the other is a couple Hundred Bucks.
I say Chop the Muffler, if it's too Loud, no biggie, it was only a few Bucks, but if you Spend the Money for the Silverline, and it's too Quiet, then you're out a few Hundred.
That's what I'm thinking.. get rid of the muffler and if I don't like it then go for the silverline.
How do must people remove the muffler? Torch it off and weld in a new pipe?
Have you guys priced Silverline lately? Its definitely on the more expensive side.
I know it isn't gonna be cheap. $475 for 4in SS turboback with tip.
i say cut it and leave the de resonator wich i think the 02 your dad has should have on it, but get rid of the cat.
saw is the best tool for the job and fastest support exhaust with jack stands to keep from binding on the blade
I have a demufflerer. I can sell you the Idea for cheap.
my 02 has a muffler and deresenator and someone already stuck a chunk of pipe in where the cat used to be.
Silverline prices aren't bad if you look hard enough. http://www.alligatorperformance.com/product_info.php?products_id=2837
there is no resonator or cat. Just a muffler unless it is cali emissioned. What are your intentions though? Just sound? Performance? EGT's? If your only reason is for sound then chop the muffler.
Thats not bad at all.. only problem is shipping. I can pick it up from my buddy on the way home.
Just sound I think. Better mileage will be nice, but I'm looking at a predator for it. I won't run it more than +65hp, so EGT's shouldn't be a problem.
