Balancer pulley R&R.
Bullseye240
Member
Naples Italy
Ok helped Gunner0812 a little on his truck today and thought I would post some pics of the work.This is the offending part.
When removed we see that the rubber has lossened itself form the outer ring and allows the pulley to rotate until contact is made with the attaching bolts causing this:
On the plus side GM did design this part so that if it did (and it most likely will) fail. It won't fly off causing severe damage. It seems they installed a bearing in the center that would only turn if the rubber broke down and the outer ring was free to turn. they even thoughtfully included a stop pin to ensure it wouldn't rotate 360 degrees and keep the water pump from turning.:thumbsup: Although as sen above the bolts do a fine job all on their own!
As you can see the pulley simply has four 15mm bolts holding it on to the balancer, no need for a puller to remove. If its stuck a few taps with a rubber mallet should free it. Installing the new one is a simple as bolting it in place and re-installing the accessory drive belt.
Good job guys!
I'm curious why you didn't also replace the harmonic balancer, especially if you were already in that far.
-Rob :)
Balancer didn't look bad to my eye and it only has 180000 miles on it IIRC. Mine currently has 240000+ on it and looks no worse than his. In short it just didn't seem to need it and the puley is'nt that hard to do if it needs it later. 1 Belt and four bolts. Truck is considerbly quieter now BTW.
The mileage is actually 130K. :D
