shortcircut65
LT OFD N-49
well, im finally down to the block on the pass. side. would the head gasket be bad if there is no black, only steel showing on most of the back side? (sarcasm) i was very supprised at how easy the head bolts came out for me. i had to put all of my ass behind it to get them off, but came out quite nicely. i was suprised at the 4 on the outside of the valve covers. the best part was when it was on the bench, and i tried like hell to get the intake manifold off, i then realized that there was a bolt in the intake that was covered up by a shop towel. :mad2: but i got it off, rockers off, return lines off, injectors out, just waiting for tomorrow to get the other side.
1) what would make my injectors so friggen sooty, that it looks like the fuel cant even get out of the nozzles? there was soot just caked on the damn things! there is only 16,xxx miles on them.
2) the injector cups, unfortunatley, i left the camera at the garage, so i dont have pics, but is it the "sleeve" that the injector slide in in the head? the machine shop said that i needed to take them out, cause some of them stick a little too far down, and they get hit by the cutter. how would i go about removing them? do i just tap on them lightly with a screwdriver or something?
3) with the heads off, i know see the pistons! never actually seen them before inside of the motor. they look fine, just full of soot is all. i found the leopard spots on the top of the walls, but found something else too. cross-hatching if you will down the walls. kinda bugs me a bit, ya know? is there anything i can do about this? to clean it up or something?
4) looking at all the parts off the truck, i was peering into my intercooler tubes, and boy are they dirty!!! what is a good cleaner to remove all the dirt and crap that i cant wipe out?
thanks for any help and ideas guys!!! i really do appreciate it, very much!
