iamdave0887
Here Comes Chaos.....
http://www.youtube.com/watch?v=i0BuqnkwAxM
You can hear it right around 1:33 or so. It's a groaning/moaning sound.
I can't figure it out. It started doing it about a week ago after a week of heavy rain/high humidity. It doesn't occur every time. Maybe 50% of the time, and the rest of the time it's silent.
The pedal feels perfectly fine. No air, no binding.
When the noise occurs i can feel it in both the pedal and the shifter and it's there and gone in under a second. The only time the noise will "stay" longer is if i feather the clutch pedal(basically beginning to stall it in gear but then letting up before the engine stalls out).
It's only when bringing the clutch pedal back up and in gear. No load on the clutch and the noise doesn't show it's face.
I can stall the truck in gear so i know the clutch has a good bite.
I've heard everything from "run it" to a contaminated clutch disc.
How can the disc get contaminated after it's been installed though?
There's not 3,000 miles/3 months on this clutch/pressure plate/TO bearing, and the flywheel was cleaned up at a machine shop before this new clutch went in. The flywheel was brand new out of the box when i did this conversion back in 2009, and has maybe 1K tops on it since then.
Since i don't have much of a choice i'll run it for now, but would like your opinions on what the hell that noise is.
Thanks,
- Dave
Thanks,
- Dave
