Walbro- no improvement
Either your tank sock is clogged or you have crud clogging the line between the LP and the FFM. Need to disconnect the line at the LP and FFM and blow/flush it out to be sure. Or put enough pressure into the fuel tank and blow the sock right out :)
What will happen if I blow the sock off? This morning I had pretty good pressure, always seems better when it's cold. After work I had almost zero at idle. Drove 4 miles and had 3 lbs. Getting sick of this hassle
I have blown 120psi into my tank in pulses about 100 times and the damn sock didn't blow off... Once again, be sure to remove fuel cap first or you'll really strain your FSU.
well shoot the 120psi in there with the fuel cap off and see if that helps out, if so then drop the tank to remove the sock and put an in line filter on there. One of those cheap clear ones in line will do the same thing as the sock, but be cleanable outside of the tank. Or put in a 20-30 micron spin on filter.
