Alright it started this afternoon, I went to check a bridge we are building. When I got there I put it in park and let it cool down a bit. I noticed a slight unusual vibration on the driverside but wrote it off to the tractor working there. when I got back into the truck I noticed it again, I stopped and let it idle while I stepped outside. it kinda sounded like the exhaust manifold had a leak or something similar. on the way home everything was normal, boost egt, temps, no white smoke, everything checked out. it goes away when I give it a bit of throttle. it only is noticeable when it idles. I got it up on my lift and it seems like its coming from the torque converter. It sounds like its coming right from the bell housing. ???. oil levels are normal. It still pulls hard and the tc locks like normal ill try to get a video or audio clip to you guys soon. The best sounds I can compare it to is an impact wrench only a bit quieter.. in park the speedo jumps, sometimes up and down up to 10mph. im currently at the shop typing this on my phone and can't search so sorry if this is a repost. any help would be appreciated. thanks
