Ultra Gel tech assembly lube
UGT (Ultra Gel Tech) is an extremely High Performance Assembly Lube. It is designed to provide protection during the initial break in of components such as Camshafts, Lifters, Rocker Arms, Push Rod Tips, Gears and more. It is formulated with Extreme Pressure Lubricants that can protect the components during initial startup of an engine.
Originally developed for Top Fuel Drag Racing Engines which see incredible pressures and Temperatures, it is now available for all applications. Simply apply a small amount to any component and assemble. UGT is designed to cling to the component until normal oil flow occurs when it will simply disperse in the oil and continue to provide a measure of protection.
THERMAL TEMPERATURE RESISTANCE:
Over 750F
PRESSURE CAPABILITIES:
In excess of 350,000 psi
ACCEPTABLE SUBSTRATES FOR APPLICATION: All metal surfaces
CHEMICAL RESISTANCE: Good
NLGI GRADE: 2
RUST RESISTANT: Yes
WATER RESISTANT: Yes
