turbo oil supply
deezl duly
riverside ca.
hey folks been slowly but surely pluggin away on my new motor for the duly,and ive got a question. as ive stated before, i got a long block from teds, and i guess these were non turbo engines so my question is,does the oil supply line for the turbo come from the front upper right side of the engine? there is a plug there and its the same size as the fitting on the end of my oil line. this truck has been apart for the better part of year,and on top of not being real familiar with it ,i dont want to ruin a new turbo by hooking up an inadequate supply line.thanks for your help
yes, on the passenger side front of the block is where the stock location for the side mount turbo supply. There's a plug in the valley which is the oil supply port for the valley mount turbo. That's where I'm gonna put my OPS.
If the block for some reason doesn't have that plug use a "T" fitting on the Oil Pressure Sender or get the plug on the block by the oil filter.
thanks guys that plug is there just wanted to make sure.the braided line is the proper length so il put it there. thanks for the help.
Just make sure its clean and tight and use thread sealer, cause once you get everything bolted to the front of the Motor you can't get to it
