Turbo Boost Bolt for Cummins
Burning oil
LeroyDiesel.com
Vendor
Houston
Hello, I usually hang out in the 6.5 section. Anyway I discovererd today that a shorter vertion of the Turbo Boost Bolt (TBB) I make for the 6.5 will also work perfectly in the Cummins. I have a 93 and a 97 12 valve and can say for sure it works on those engines. I'm not sure how different the 24 valve, 4bt or 6.7 are, maybe someone can educate me.
Anyway this TBB replaces one of the stock bolts in your intake. It picks up the pressure and sends it to your guage. Takes less than 5 minutes to install (the TBB itself, not the guage....)
Please see my web site for more info. Right now I only have the info for the 6.5, but it is the same info for a Cummins. www.pmdcable.com For now you can PM me if you want to order.
Leroy
TBB
Installed in front intake bolt hole.
Or, behind the air inlet makes a nice spot. I think you can use any of the inboard bolt positions.
Thanks for looking.
I was able to confirm it will work on the 24 valve and 6.7. I'm 99% it will work on the 4bt. I will keep researching that.
It gives another 10#'s..:eek:hmy1:
Just kidding and I think you are to. It just "taps" the intake, a very easy way to read boost pressures.
