Trans go JR. PROBLEMS!!!!!!!!!!!! please help haha
mkusmaul
so i jsut put in a trans go jr on my 07 LBZ and i checked over everything b4 i bolted up the tranny pan. then got all the fluid in and everything checked and started it up and let it warm up and then the P0700 and P0877 and it would go through Park reverse neutral drive and manual and first but you wouldnt move anywhere. then it i dont know weather the tranny started getting warmed up sum fluid flowing but then it would go in reverse and nothing else and then after a while in drive, so i lightly drove a little bit and it wouldnt go past 3rd gear, then i stopped and dropped it into the manual shifter and it was still in 3rd gear. so i dont know wats wrong with it, SOME ONE.... anybody help:D
I think you're gonna have to take it apart and redo the whole thing. You must have missed something.:noidea: I've never done one so I couldn't help ya there.
Check your fluid level.
If that doesnt work pull everything apart, clean it up good, double check that it is put together right, put some di-electric grease on the connectors and put it back together.
If that doesnt work have the dealer figure it out, its hard to trace voltage drops without dealer tools
