Welcome to TTS!
Is your towing for recreation or profit? If you do a lot of towing your MPG becomes important enough that you can justify replacing the turbo with a bigger one along with supporting mods like a tune and exhaust in 15,000 miles.
The GM turbo is simply wasting fuel over 2200 RPM making the cooling fan run and eating power. Check the 6.5 performance section for dyno results of a larger turbo under towing/full load. It is worth over 50 HP and torque past redline.
I have towed hard, hot, and heavy with my 6.5 and sent a couple of 6.5 engines to scrap metal. My biggest problem was the GM3 turbo followed by the cooling system unable to get rid of the heat trapped by the exhaust restriction of the GM3 turbo. My biggest regret is F#*&ing around with turbo masters rather than just ripping out the turbo for a bigger one. But at the time info was not easy to come by about it. The Turbomaster allowed more MPH over the 1993 factory spring can - not sure if it does much over 'newer' vac systems.
So towing in mountains with a larger A Team Turbo got me: less cooling fan use, 10 MPH faster (from 43 MPH to 55 MPH), 3 MPG increase (7 to 10.4 MPG), and payback in fuel saved of $1500 invested in A Team Turbo, 4" exaust/converter, and tune in 15,000 miles of towing. This is with a 24-28' trailer on 7% grades in 32 to 114 degree weather.
So cheap turbo master spring fix or expensive fix that gets you more power and MPG towing and pays for itself...
There are other bigger turbo's out there as well. Feel free to discuss them on here as we are allowed to :thumbsup: Again Welcome to TTS!
