..... Also told me that the smaller turbos tend to mask the smoke....
I would say it has to do with the transient response of a smaller unit. I guess in a round about way it can mask too much fuel by providing enough mass at the throttle setting demanded.
Bigger or stock turbo choices depend on what your goals are......
If you mash the pedal on the gm obd 1 and obd 2 do you get fuel fuel the max the pump will put out the minute the APP sees full throttle.?
Maybe, maybe not. It's not as simple as dumping in fuel. Depends on what variable fall into what position on the tables that come into play. So, while you may call for WOT, you may not get the maximum 79.9 mm3 the programming is limited to. Chuck in timing, temperatures, pulse width, etc and things get even more complex.
I've dialed timing out as boost comes up. I've yanked out fuel in some cases. There's general rules, but there's just no substitute for a data logging run in actual conditions.
Is there a way to tune the truck to not smoke?
Yup. Mine doesn't smoke anywhere except a puff at start. The most I see with either my own program of the Heath PCM I have is a barely perceptible haze and I have to be on it really hard and heavy to get that. You can deal with "smoke" with more than just the fuel variable.
I suggest that the tuners can make any truck smoke and that just giving it more fuel does not make power, hence some tuners that don't know or never have run a set up can make the truck run poorly just by tunning it improperly, from not knowing or make the truck run poorly just because they may not recommend a set up.
Agree.
In extreme cases, they can damage the engine.
I know KOJO has obd 1 and obd 2 tunes that smoke less and have power because he has run and tested the truck and made adjustments to the tune while driving the truck for a particular set up.
That's the way to do it. Unfortunately, "tune in a can" is what you get unless you can have the truck on the spot tuned. Most "tuners" get close enough that the last little bit isn't really needed. That goes for all the EFI/duramax guys running around out there too. There's some really good guys and some guys that should step away from the laptop....
Now, if you have something really custom.....well, you need a guy local or learn to do it yourself.
There are others that tune well also but some tuner's tunes seem to smoke more than others, is this a tuner issue?
Pretty much, barring a mechanical failure of some sort.
Speaking with a tuner for GM regarding the 6.5 diesel he stated that data logging over many months and then running computer simulations with that data is how they get a good starting point for a tune. One that gives drive-ability and fuel economy with good emissions. I know for a fact the fuel delivery systems on these systems are not just a progressive linear fuel line, they have hills valleys and peaks that make the fuel curve. Any programmer thoughts on this?
Nothing other than; "correct on all points".
Where power is often found is the "good emissions" point the OE's achieve in conjunction with power and fuel economy.
NOx is often traded off for hotter burns. Many other hydrocarbon emissions are also mucked around with.
Not that they all do this, but it's difficult and expensive to work up a tune to make more power and maintain fuel economy/emissions.
It's all a trade off, that's why OE's programs come out of the factory the way they do.
There's so many factors to consider: crank angle, burn time, propagation, throttling losses, etc, etc......the more I learn, the more I can't believe they ever find a point to even start from...far better at it than I am (OE's that is).
The other trade off is longevity.
Gotta make it last until the warranty runs out.......
That's just my opinion/outlook, I sure don't have all the answers so I'll sum up with a standard "YMMV" and check it out real good before you drink that Kool aid......
