The limits of conventional oil.
WarWagon
Well it hits on 7 of 8...
AZ
Looks like I reached the limits of conventional oil. Likely soot is causing it to change from 15w-40 to the 50 weight reading. Overheating of the oil is also possible. I was dealing with a possible sticky t-stat and confirmed bad temp sender - both were replaced.
Never heard of the vis rating going up in that short a time. I've never used conventionals other than Rotella or Delvac though. Is it normal to have oil break down that soon since you drive in an oven 8 months out of 12?
I do my oil change every 3,000 to 4,000 miles. I use rottela(cheap) on sale preferably.
WW you have convince me that if there is a way to break something you have accomplished it, all! :thumbsup:
Sounds like it could be a bad UOA report. I'd have it done again, if you still have any of the sample left. Somethings not right there.
How bad was the previous change? I have wondered before if the previous change was overdo or as bad was there a lot of left over oil in the cooler to contaminate the new oil such that it depletes the additive package quicker than it should.
Wonder if a brand change might help or have hurt with different additive package?
That is one of the draw backs to having only 8 quarts of oil in a diesel less oil to dilute the soot and crap.
I use to worry more until someone posted you don't see many wear problems with 6.5's they usually die from something else ;-) .
