Synthetic Vs. Conventional
merlin5577
Diesel > Gasoline
Taunton, MA
Ok, we have all heard the talk about Synthetics causing leaks in older vehicles. I personally have never experienced this but was wondering if any 6.2L owners had. I changed over to Synthetic everything in my 97' at 100K and have never had a problem, and my Silverado has had Synthetics since it was new, so if I change to synthetics in the 6.2, I dont beleive I will have any problems but.......... always best to ask.
ANY advice, input or personal experience stories are appreciated.
Thanks!
I have never had synthetics cause leaks. My stupidity while working on vehicles and my lead filled right foot on the far right pedal has caused leaks and holes were they are not suppose to be.
Synthetic oils do not 'cause leaks', but they can reveal them. What can happen is this:
When an engine with degraded gaskets/seals has sludge/deposits built up, any faults in the sealing surfaces which cause leaks can be slowed and even sometimes stopped by the gunk in the lubricating system. It acts kind of like Bars Leak.
Then when synthetic oil with a robust dispersant/detergent package is used, it will 'scrub' the deposits off of the engine internals. This will now allow any degraded sealing surfaces to leak.
If an engine is in good repair and has been well maintained, switching to synthetic lubricants will not be an issue.
I personally think synthetic oils in our 6.2's are a waste, unless you live in the desert or the arctic. We can't run extended drain intervals due to the oil getting contaminated so fast so unless you live in extremes, tow in extremes and/or run a filter bypass setup, its pointless. Just run some good oil, IE Rotella.
x2. Rotella is great oil.
