Sudden trouble opening attachments
jrsavoie
Recruit
Rural Clifton, Illinois
I tried to open 2 attaqchments that the boss sent me.
One was Adobe - which I have never had a problem opening before and the other said it could be opened with Microsoft paint which should be on my computer with Windows 7
The Adobe Download fixed the first problem.
What do I do to fix the paint problem?
Any advice as to where to download paint?
This is the message I got when i tried to open the file
Windows has the following information about this file type. This page will help you find software needed to open your file.
File Type: Tagged Image File
File Extension: .tif
Description: This document is a graphic image. Microsoft Paint which comes with Windows can open this file.
Software or information available at:
Adobe Photoshop
CorelDRAW
IrfanView32
LView Pro
Microsoft Digital Imaging Pro
FastPictureViewer Professional
Paint Shop Pro
Free File Viewer
You may search the following Web site for related software and information:
Search the web
1. Navigate to the folder that contains an .rtf document
2. Right-click on the .rtf document
3. Select "Open With"
4. Select "Choose Program"
5. Select/highlight the program you always want to use to open .rtf documents, e.g., "Paint" (I prefer a word processor like "Word")
6. Check the box next to "Always use the selected program to open this kind of file"
7. Click [Ok]
The OS may try to open the application that was used to create the document.
If you try to open an .rtf with Adobe Reader, it would, most probably, error out with "unsupported document."
However, if you try to open an .rtf with Adobe Acrobat, it would generate a .pdf from the .rtf, then open the generated .pdf.
