Suburban Replacement Fuel Tank and Fuel Line FYI.
nobby
Old Timey Diesel Guy
Long Island NY
I just replaced the Tank and Fuel Lines from the Lift Pump back on my Burb:
Fuel Tank was a Spectra GM43B and it came with the Metal Baffle Box installed.
Fuel Lines were pre-bent from Lines To Go (Lift Pump Back Kit FL507-DD1 for the K series) and were a great match and installed with only one adjustment which was changing the bend at the supply line fuel tank end which was no real trouble and I called them and informed them of this so hopefully they'll deal with it.
I did the sender also and went with an AC Delco unit.
Cheers
Nobby
