My problems got worse friday afternoon at the distributor I get equipment from... it's been SLOW cranking, that I attributed to cables, but the cleaned up nicely, with zero signs of corrosion on them, and I just have NOT had time to swap in the new raceman cables yet... it finally went crankcrankcrankgrrrrr.s.ss..s I knew the signs... and called up carquest (man they are pricey for a starter and core!!!) dropped the starter out, popped in the carquest one, and WOWOWOW! that thing sure cranks fast!
if your starter doesn't sound like a diesel gear drive motor starting, you should replace your starter! ahrurarurrarurrr is NOT normal starter cranking... it should be chikraroom! very fast cranking... still have the stock cables, but once I clean the gunk from the motor, and get a slowdown, I'll drop it again, and install the upgraded cables, and fix whatever that small wire is up near the glow loom...
